Device Assignment
Device assignment allows you to assign specific device profiles to a user. If the device assignment feature is enabled, users are restricted to the assigned devices when logging into InGenius.
You can configure monitor InGenius "monitors" the integrated telephony device when a user logs in. This process is referred to as a monitor. parameters for your telephony system via the InGenius Configuration Tool. Any monitor parameters enabled from the Configuration Tool can be added to a device assignment profile.
